I prefer voltmeters as well. You can have a ammeter system by having all the current go through a high power, low resistance value resistor, a shunt resistor.
The voltage "V" across a resisor is equal to the current "i" going through the resistor times the value of resistance (V = iR), or i = V/R.
For example, you would feed the red wire from the alternator through a high power resistor (mounted to the firewall) and the other side of the resistor would go to the car's electrical circuit.
You would then meaure the voltage drop across the resistor by a voltmeter.
For example, if the voltage measured across a 0.05 ohm resistor was 2.5 V, then a current of 50 Amps was flowing through it.
What this shows is that a high power resistor of 0.005 or less ohms is needed to measure current, so that the resistor doesn't drop too much voltage across it. With a 0.005 ohm resistor, you would measure 0.25 Volts across it with a current of 50 Amps.
Let's further assume that you need to measure up to 150 Amps.
The power dissipated in the resistor would be:
P = i^2*R = 2,500*0.005 = 12.5 Watts.
So a resistor of 0.005 ohms with a power rating of 20 Watts would be necessary to measure currents in a car's system.
Edit: Some amp measuring systems or kits come with a shunt resistor and a voltmeter calibrated in Amps. So on the firewall yould have four wires coming from the shunt resistor. A heavy 10 or 12 guage fuse wire going to the shunt resistor, another heavy wire spliced to the cars electrical system, and two 18 guage or less wires from across the resistor going to the voltmeter, again calibrated in Amps.
[ March 29, 2003, 05:46 PM: Message edited by: MolaKule ]
