How about a S3569 for my jeep?
Apple Valley, California
Found today @ autozone. Same specs as the #16 and 8 that will work on my jeep.
Has a base mounted bypass, metal inner tube.
Looks and feels just like the mobil-1 but was $3.49. Definatly not a Clicker or Ecore.
Wix specs-->Part Number: 51452
UPC Number: 765809514522
Principal Application: Audi (78-83), Dodge V10 8.0L (94-99)
All Applications
Style: Spin-On Lube Filter
Service: Lube/Transmission
Type: Full Flow
Media: Paper
Height: 5.178
Outer Diameter Top: 3.660
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Burst Pressure-PSI: 415
Max Flow Rate: 7-9 GPM
Nominal Micro Rating: 19
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.834 2.462 0.200
Verses the filter my jeep calls for (PH16)
---> Part Number: 51085
UPC Number: 765809510852
Principal Application: Chrysler/Dodge/Jeep Vehicles (91-05), Mitsubishi Eclipse (95-99); Caterpillar 3 Series Excavators, 9 Series Loaders
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.790
Thread Size: 3/4-16
Beta Ratio: 2/20=15/28
Any reason not to use it? I got plenty of room
