Some background:
I've have a peer-to-peer home network and one of the computers on the network is a file server. The file server uses an Asus P3B-F board with a 20 GB c: Windows XP OS drive and a 1TB d: NTFS data drive using a pair of SATA drives plugged into a Vantec UGT-ST220R controller with RAID 1 configuration. When I set up the 1TB drives, they were configured as a dynamic disk - don't recall exactly how that happened.
It was working perfectly for several years until I noticed that I was running out of free space on drive c: and started screwing around with drive indexing. While turning off drive indexing, my 1TB drive disappeared and now appears unformatted.
With a recovery program (DiskGenius on Hiren's BootCD), the files appear intact and I am in the process of copying them to an external drive.
Request for advice:
The RAID 1 1TB drives are obviously for redundancy. If one fails, I would like to be able to use the remaining good drive to copy my files to a new mirrored drive setup or to install that drive in another computer. My understanding is that the best way to do this is for the 1TB drive to be configured as an NTFS basic disk.
Long term, Linux might be a better option than Windows XP.
Request for advice:
- Would Lubuntu work satisfactorily for this purpose as the OS in my file server?
- What would be the best way to configure Linux for remote access on my home network with my other Windows 10 computers.
- Any other advice?
