Highlander Shock Replacement
Austin, TX
I bought KYB-ExcelG for my highlander front shocks and while replacing them I realized that the strut support assembly has 2 arrows marking the front and the spring seat marker as OUT.
The spring seat has a margin of +/- 5 degrees from the OUT markout, does it have to be this accurate, I kept the OUT facing outside and installed the shock.
Pl. chime in.
Did you have a 4 wheel alignment done after your installation? I think this is the purpose of the markings. FWIW
Oldtommy
