OVERKILL
$100 Site Donor 2021
Originally Posted By: Tempest
Precisely. Now think of this the other way.
Since oil and coolant temps are not 1:1, it would be fair to assume that in the frigid cold winter, oil temperatures may get nowhere near what they would reach in the summer. Even with the coolant the same temperature.
In cases like this, it may be beneficial, if conditions (both mechanical and ambient) allow the move to a lighter oil to improve start-up performance and to get closer to your summer "hot" viscosity, which is likely closer to "optimal" for your engine.
His question was about high heat, not extreme cold. If you live in areas that get deep into the negative F, then I agree that a lower grade maybe beneficial. This is because oil viscosity change is not linear. There is a much greater change at lower temps than there is at higher temps.
Yes, but my original reply was in response to this statement you made:
Quote:
The thermostat in your car determines how hot your engine runs.
Because of course the thermostat does NOT determine how hot your oil gets.
You then started talking about Death Valley and extreme heat testing, so I figured I'd mention that extreme heat isn't the only reason for somebody considering a deviation in viscosity from the manufacturer's spec.
And of course you touching on modified engines fits right in there as well.
