Thin oil test in LS1, Test 1.
Miles on oil.....3,342|2316
Miles on unit...90,068|94343
Element....M1TrSUV...HavDS...uavg
alum..........3..2..4
chromium....1..0..1
iron.........19..3..15
copper......4..2..34
lead..........0..0..7
tin............0..0..2
moly..........6..142..60
nickel........1..0..1
mang.........1..0..2
silver.........0..0..0
titanium......0..0..0
potassium....3..0..1
boron.........32..28..68
silicon.........8..4..6
sodium.......3..1..6
calcium.....2503..1628..2307
magnes.......460..44..293
phosph......1077..547..737
zinc........1299..689..880
barium......0...0...0
Visc (65-78)..73.7,,,55.8
Flash >375...445...435
Fuel Antifreeze..0..0
Water...0..0
Insolubles.... 0.5%... 0.2%
Lab Remarks: Wear is virtually non-existant in this sample. We've seen more wear metals in a virgin oil sample than we found here. Your note implied that this was a rinse phase so we understand the short oil run. Try 4,000 miles for the next sample. Wear will increase but it should read close to universal averages, as that is the mileage upon which the averages are based. The viscosity of the sample was slightly low but isn't a problem and no harmful contaminants wer found. At 94,343 miles we have no problems to report.
My remarks: The previous oil that was used for the ARX treatment was Super Tech 10w-30. The oil before that (UOA numbers listed above) was M1 TrSUV 5w-40. This oil was Havoline Deposit Shield 5w-30, chosen for it's low viscosity in the 5w-30 population. Normal viscosity is 59.4 and thinned to 55.8.
The intent was to have a low viscosity oil to splash around and clean off anything the ARX had disolved and to test the Thinner-Is-Better idea. The oil was not babied while in use. There was city and highway miles, a heaping handful of WOT runs, a lot of two-lane WOT passing of slower cars (I love that in the Z28), and a run up to 112mph. The current fill is Castrol Syntec 5w-30, which is a slightly lower viscosity.
The common thought is that LS1's are supposed to really love a thicker oil, but I don't think it's the thickness as much as the oil itself (GC comes to mind). It looks to me like LS1's don't mind a thinner oil at all.
chromium....1..0..1
Water...0..0
