Gx460 viscosity
This isn't a dead horse topic as I can't find a detailed discussion about it on this forum. My brother bought a gx460 1urfe (very very similar to the 3urfe 5.7). He lives in a very hot climate all year round in the usa. If I were him I'd be running 5w30 despite the reccomended 0w20. From My oil research there doesn't seem to be a huge difference between those two different grades of oil. But from my research toyota/lexus reccomends 0w20 only in the usa, and other countries they are told to run 5w30- 15w40. I want total confidence to tell him to run 5w30 or 0w30 over 0w20. Anyone have any more info on this topic? Any advice
What is a very hot climate? Currently running 6 quarts of Rotella 5w40 SM and 2.5 quarts Total Quartz 5w40 Energy 9000 SN. It’s been well over 100 degrees nearly every day in Texas since May.
Southern tip of Florida. Do you have a gx460?
running 0w-30 Amsoil Sig.Series in my `18 1GR-FE 4Runner. May go to 5w-30 HPL Prem.Plus. PCO when my 0w-30 is gone.
It says in my owners manual to go thicker than 0w-20 if you run it hard.
Numerous topics with question: “it is hot, therefore…”
Cooling system maintains oil temperature. Heat per se is not an issue as for example altitude is. That is where system might not be sufficient bcs. air density.
In GX460 cooling system is more than sufficient to deal with any ambient temperature for type of duties vehicle is made.
Also, when one runs thicker oil, resistance increases =more heat.
I personally would run 5W30, but just info that running engine at Vail Pass in CO in 80 degrees is more strenuous than running vehicle at ANY temperature in TX or FL.
I have a 2019 GX460 and have posted several UOAs, including Mobil 1 AFE 0w30 (Jan 26, 2023). Expecting another UOA any day now from blackstone - again with m1 AFE 0w30 and 7k plus miles on the oil (mailed mid August…)
My latest fill is 5 qts castrol edge 0w20 and 3 qts castrol edge 5w40.
You can search for my UOA threads with gx460 and 1ur-fe in the search prompt.
The lexus manual has similar language to what zfasts03 states about his 4 runner.
0w or 5w-40 M1 Euro. 20 weight is CAFE economy oil.
