Paint is only worth the effort you put into it...and only as good as the base itself.
OT: but I need some advice.
Whipped out the Metabo and brought all the loose paint off the flat surfaces on my wrought iron gate. Than used 1/2" Wide bridle version on a drill to reach the underside of the fence. I knocked off about 50-60 of the underside which is as good as it's going to get...
I thought I knocked off all the loose areas on the curvature shapes of the wrought iron.
Started painting today. Notice I missed quite a bit on the curvature spots so I plan to reattack this once more.
Is there a faster, better way of doing this just short and steady.
Had it been a easy choice, I would have cut it all, brought it to my guys who does powdercoating and then reweld it back. Ha, if only he had a media blaster large enough ;-)
