Hello all.
I have two items on my WRX that need grease and that I need to know what would work the best.
One is the front wheel bearings. I have to remove the knuckles to service the ball joints. I also have to replace one of the knuckles. Thus I will be doing some disassembly work. Before I reassemble everything I would like to use a grease that will both hold up and not be affected by water.
This car is a daily driver, an occasional spirited driver, and the occasional auto-cross driver. I'm in the Northeast so water and road-salt are a concern. I have new bearings and seals as needed for this job just in case. The car currently has 22k miles on it so it's still relatively new.
The other area of service is with respect to the swaybar bar bushings. I have urethane bushings that I manually lubricate (no grease fittings). Currently I have been using LocTite ViperLube NLGI-grade 2/Severe-duty GC-LB synthetic grease. I got it as part of a promo package at an auto event, read a little about it and decided to use it for this particular application. So far its held up pretty well.
My main concern is the grease for the front wheel bearings.
Any suggestions?
I'm limited as to what's available around here. IMO, there are no real good suppliers of 'specialty' or even 'over the shelf' greases, other than the standard lithium based or moly lubes, etc.
Your assistance is greatly appreciated.
Any suggestions?
