Originally Posted By: 440Magnum
I guess "fine" is relative to the diameter, the teeth are still fairly decent sized compared to anything you'd find in a car.
The other thing I find really cool about steam ship plants is that the thrust bearing has its own compartment astern of the bull gear, with its own oil pumps and cooling systems. Think about how many thousands of TONS of forward force there is on each shaft when its working, and the bearing built to absorb all that and couple the propulsion force to the hull is huge and generates a lot of heat.
Hope Google Books Link Works
Some interesting commentary, as back in the day, the different manufacturers specialised in either impulse or reaction blading...Parsons (first to put a steam turbine on a boat IIRC) like reaction, but reaction HP turbines lack efficiency, while impulse rule up that end.
As to thrust bearings, the Tilting pad thrust bearings (aka Michell bearings after the inventor are an amazing piece of kit...they can take staggering loads at near zero speeds, as the pad itself can tilt, and has a centre of hydrodynamic pressure slightly ahead of the pivot point, causing the pad to tilt, creating the closing gap that generates the hydrodynamic pressure.
Dyno testing the turbines can be done in the shop, hooking up to a generator and load...can measure shaft "twist" and RPM and calculate back, or load sensors on the mounts.
(most I ever got out of one of my machines was 998,000hp...couldn't get the last 2,000, even bumping up to 2,357 psi).
