I think a sticky reminder would probably help.
I believe it has to do with the fact that:quote:
Originally posted by NovaMan:
What does a turbo do to emissions, and why can't it be made to pass emissions tests by careful tuning and engineering?
Or maybe the EPA should get its head out of its *** and realize that throwing away energy in the form of heat is not a good thing?
Since I hear that the next gen Cobalt SSes will be turbo (a la Solstice GXP), I really do hope that GM engineered/built this Ecotec's block/bottom end very strong. It is much easier to find limitless boost with a turbo than with a supercharger, and you will have every kid buying one of these trying to see how big a turbo they can bolt on, and how much boost they can push!quote:
Originally posted by s4audinut:
This thread is all over the place... I thought it was good that GM (even tho I think they are the G Bush of the auto world)did a good thing building a good block and leading everyone by the hand to further mods. Wish I had had a handbook when I decided to take my 2L Audi to 300hp per L. Rice, spice or dice, anyone who does an engineering guide complete with making the very expensive side trips for you deserves applause. On the domestic side I am a Ford guy all the way, but this is admirable. And you will find out how valuable if you ever venture 'where no man has gone b4'. I have been very impressed with this forum and the honest advice and deep thought that seems to go into most replys, but this one reminds me of Audi World.
Rod
As a wise man once said, "There are no displacement classes on the street."quote:
Originally posted by Nick29:
S4audinut, that's because hp/L or hp/ci is not much more than a marketing ploy. Not that it's not cool to see a motor that makes L, but hp/L isn't nearly as significant as the power:weight ratio of the engine or car.
And with that wisdom, this thread should end.quote:
The LS7 is hand built. It makes 500hp from the factory and is an intake, exhaust, and cams away from a daily driveable 600 crank horsepower. As much as I like the SRT4 and Cobalt SS, there isn't a 4 cylinder on the market that could handle daily driving with 600hp at the crank, and I don't believe for a second that there's a market for a 600hp factory turbo 4 cylinder or that it would weigh much less or be cheaper than an LS7 (which is sold as a crate motor for a little under $15k).quote:
As far as lighter, I beleive you may be dreaming unless you are talking about a special all aluminum casting with sleeve inserts and then the cheaper go's out the door.
