Need a little advise if possible. A couple months ago my wife told me our GE Hydrowave top load washer started acting up. When on the x-large load setting it would cycle from water fill to wash, but the tub wasn't full yet. It would quickly cycle back and forth. I offered to look at it but she insisted later because she had laundry to do. She changed the load size to large and the "problem went away". Well like most things it isn't fixed, I forgot and now it is doing it on the large setting as well. My question is any thoughts on the problem and solution before I tear into this thing... My google investigations tends to tell me it is either the lid switch (simple fix) or the clear tube to the water level diaphragm (another simple fix) is causing the issue. Anything else it could be?
Any help would be awesome, thanks!
