I had been trying to find this. It's a little old (2014) but an interesting read.
Once again, not a minute's thought goes into how efficient the electric cooking system is when considering BTU consumed to make the power, vs, BTU that makes it into the food.
Because it's probably no better than 15 to 20%.
Try running a generator to run your electric cooktop to boil water. Then consider how many BTU worth of gas was consumed to do the job.
Oh, but a gasoline generator is inefficient you say. Sadly, a good gasoline generator mirrors today's fuel powered grid efficiency.
Similar to electric vs gas car comparisons that ignore losses in electricity generation and delivery through the grid.Once again, not a minute's thought goes into how efficient the electric cooking system is when considering BTU consumed to make the electricity, vs, BTU that makes it into the food.
The Control part of your post is not correct when it comes to induction cooktops. Maybe you can't see the flame, but the changes in temp ARE immediate since there is no insulating layer between the pan and the heating element. As far as control is concerned, induction iis even more immediate than gas. There are no "coils to heat up" on induction, and you have a number display to tell you exactly what you are doing. You want to lower the heat a half a number? Pretty simple. Even gas has latent heat in the support and the burner itself, so induction is even MORE immediate that that. Your brain will still handle the numbers on the dial just as easily as it does seeing the flame.I care far more about control and reliaibility than I do efficiency and cost.
"Control" is my ability to see the flame, and make very subtle adjustments very quickly. With electric coils, I cannot see an immediate change. Gas ignites "now" and changes instantly upon my inputs, whereas coils have to ramp their way up to some value I select on the dial. Induction is similar to electric coils; I have to move the pan off the surface to "see" what's happening, and because of the ramp up/down of the electric system, I cannot see that change immediately. But with gas (propane or natural), I can see the flame profile change in a split second, and my brain can say "yup - that was enough to get where I want to be". Electric coils and induction will NEVER offer than kind of nuance.
"Reliability" is my ability to have the heat source in all situations, especially when other means fail. My area loses electric power frequently, but in the 30 years I've lived with gas stoves, I have NEVER (not once) gone without fuel to cook with. When my power went out for 3.5 days in winter about a decade ago, all I had to do to eat was plop some stuff in a metal pan, light the stovetop with a match, and we were eating soon. If I had only electricity to cook with, I would have had no stove, no oven, no microwave, no crockpot, no hotplate ... hence - no hot food. Gas delivery is FAR more reliable in energy delivery; when the chips are down, it's drastically superior to electricty.
So, I don't give a hoot about the potential for childhood asthma or how much energy I might waste.
My preference is for infinite immediate control and superb reliability in delivery
Or, more simply put ... I want what I want when I want it.
You can perform a back of the envelope calculation based on the information in Table 3 by converting kWh into BTUs based on whatever energy generation source you want to use Coal, NatGas, Nuclear, Solar, etc.Once again, not a minute's thought goes into how efficient the electric cooking system is when considering BTU consumed to make the electricity, vs, BTU that makes it into the food.
About 5800 BTU to boil a gal of water.
Not "done". Maybe in FL that's an easy fix. In Indiana, when it was -17 degF outsite (actual temp; not windchil) and we were without power for 3.5 days, cooking outside on a propane grill would not be practical or easily "done". Whereas, cooking indoors with my gas stovetop was as easy as striking a match. Further, when I was out on duty and my wife was at home with the kids, she's going to balk at going outside in negative temps to fire up the grill.The "Reliability" portion of your post is just as easily solved. Just get a propane grill with a side burner. Done
I am in total agreement.I care far more about control and reliaibility than I do efficiency and cost.
