quote:
Originally posted by buster:
From Synlube's website: (They are anti-thin oil)
No matter what oil you use for any purpose the ideal viscosity that provides the ultimate lubrication, that is TOTAL bearing surface separation, and at MINIMUM power that is consumed by the lubricants viscosity (MINIMUM TEMPERATURE RISE) occurs ONLY at ONE combination of:
SPEED
LOAD
TEMPERATURE.
Under ALL other combinations of the three factors, the lubricant is NOT IDEAL.
Ya know, once you add the real world variable of
OIL PRESSURE, the rest of their argument kinda falls apart.
So many talk about film thickness, in reality you should be concerned with *oil pressure* at the crank bearings if you are worried about using thin oil. What I have seen kill crank bearings is #1 detonation, #2 dirt, and #3 out of round rods from way too much of #1. Otherwise they last pretty good for how soft they are if you don't have any of the above problems. Thicker oil lets your engine take more of the above abuse, but in reality thats just a bandaid, you could also simply stop the abuse.
Most modern engines are now rollerized on high friction points that are not oil pressurized (cam followers), don't have cams driving distributor gears which are then driving oil pumps, etc.
Piston rings and bores are fit much better since the early 90's and last so much longer compared to before. Plus the use of high silicon pistons (Hyper-u-spell-it) gets the tolerances super tight so the rings last longer, cranks more in round, oiling systems designed correctly (think Ford Cleveland), etc.
I see absolutely no problem with thinner oils in todays cars especially with all the high tech engine management systems keeping the car out of detonation, running rich, etc. The future will be thinner oil speced more, you can bet on that.
Edit - Forgot to mention that as speed increases oil pressure increases for most engines.
