Originally Posted By: 901Memphis
There is a reason to use the Ultra, it is 99%+ efficient at 20 microns and 80% efficient at 5 microns, and has the highest capacity you can get off the shelf with a dual layer of synthetic media plus all the other goodies, thick can, thick paint job, silicone ADBV, sure grip, metal end caps with felt seals on ABDV/Bypass Valve.
Even if you only run 5k a year you can leave the filter on for 15,000 miles; that's what i do, change conventional oil at 3-5k and Fram Ultra at 15k.
I think you may want to double check your sources. Im pretty sure the Royal Purple filters have the same efficiency with more capacity. They are arguably the best filters on the market. Especially if you are taking build quality into consideration. Those things are indestructible and it takes a month of sundays to open one up. The only thing the FU has on the RP is the price. You can buy 2 Fram Ultras for the price of one RP filter. But you get what you pay for right? To each their own.
This is an older, high mileage car with a very limited maintenance history. There is no reason to put top shelf parts on it. A high mileage OCOD and some HM oil will be more than enough. It would cost more to fix the vehicle than it is worth at this point. The HM oil and HM filter are just trying to keep in on the road.
