OVERKILL
$100 Site Donor 2021
Figured I'd post these up.
Background:
This engine had 1,000Km on it. Previously, it failed in a *similar* manner, same block. Three damaged cam lobes on an OTS Trick Flow Stage 1 cam.
This is the engine that came in the car a good friend of mine just bought. He got a good deal on the car, knowing the engine had an issue. On the way to pick-up the car, we grabbed a low-mileage (80,000Km) shortblock to swap the parts onto.
Details:
-Stock Ford Windsor block
-0.030 over-bore
-Weisco forged pistons
-Balanced rotating assembly, stock rods and stock OD bearings on crank
-High pressure oil pump (the first time, this time it was stock)
-Hamburger 7L pan
-Hamburger oil pump pick-up
-Custom camshaft
-Stock-style lifters
-Trick-Flow roller rockers
-Trick-Flow Twisted Wedge heads
-Weiand X-CELerator intake
-Holley 650DP Carburetor
-MSD Pro Billet Distributor
-MSD 6AL CD Ignition (6,800RPM pill in it)
Oil used: Valvoline VR-1 20w50
Lifters: Note the pins are coming out of several of them
Lifter that spun:
Scored lifter bore due to lack of lubrication:
What happened? Cavitation and oil starvation due to excessively heavy oil and a poorly designed pick-up that has a screen that does now flow enough volume and has far too little surface area.
The FIRST time this happened, this block should have been scrapped. The lifter bores would have to have been re-aligned, which we doubt happened. The same oiling setup was maintained for the second time around, which resulted in the exact same thing happening again.
I have more pictures, but these are to start.
Background:
Details:
-0.030 over-bore
-Hamburger 7L pan
-Custom camshaft
Lifter that spun:
