Originally Posted By: Injured_Again
Originally Posted By: Finz
Injured ... I'm being lazy by not checking your original thread but how many miles have you logged to date? Was 500 miles the magic number for you as well before you noticed the improvements?
I have to go back to an earlier post from Clevy... I think he mentioned that he took a long, steady drive almost immediately after pouring MoS2 into the sump and wished he hadn't for he felt a number of heat-up-the-engine, then cool, then heat, then cool, might have been a more effective way to help the product "plate"
I could be way off here so put the pitchforks down... Been a long day and the memory ain't what it used to be.
Did you "drive" any particular way at the onset?
Finz,
I have probably 1300-1500 miles now since adding the Mos2. Clevy is spot on - it took a little bit before I saw improvements, which became noticeable maybe around 100 miles in, and the immediately noticeable improvements continued to 500-600 miles. I think even this far out, I'm still getting improvements but that may be because of the high mileage that my engine already has. The plating may be helping raise compression because I seem to feel a bit more power at full throttle. But other than taking a long'ish drive right off the bat, I didn't really do anything different.
Because this is my daily driver and I have a pretty set routine, the driving my car gets is pretty similar. Our summer weather has been really consistent as well. In the few tanks since the big improvements, mileage has gone up from a range of 27.2 to 28.2, to a range of about 29.5 to 30.3.
I'm a little tempted to add the Mos2 to the two other vehicles my wife and I drive, but they are both low mileage at 20k and 38k, and both engines are very smoothly running and have lived a life with Mobil 1 so I will probably leave them both alone for the time being.
The sooner you add it the better. Your miata is reverting to like new because of the reduction of friction. Why not keep a new engine new longer,never losing any performance over time.
I put mos2 into my 106 right after break in. Those pistons are huge,ring seal is questionable at start up but no consumption whatsoever.
Keep a new engine like new forever.
