OK, here's the facts RE: loudspeakers, amplifiers and speaker driving:
(1)speakers sensitivity ratings are not directly related to power handling capabilities.
In other words: your (Jamo) speakers may be rated to 100Watts max. @ a 1second duration, and beyond that duration, your woofer voice coil may overheat and burn out.
Speakers that are capable of handling 100Watts power continuously are mostly those that are those typically comes with aluminium voice coil former and/or aluminium voice coil wires (copper clad) to assist heat dissipation.
Some high power, continuously duty P.A. or stadium professional sound re-enforcement speakers, etc. (Beyma or JBL comes into my mind)
(2)in high-end audio we have a saying: the first watt (from the amplifier) is the most important watt. If an amplifier cannot reproduce the 1st watt "faithful" enough, the rest of the output (in terms of wattage) isn't gonna matter any more.
(3) sound pressure level (in Decibel form), is logarithmic, meaning that it does not obey the linear rule.
So, for a 90dB/1W/1m (referenced @ 2.83V), when you are sitting 1m away from your speaker (on-axis) and feed 1watt into your speaker, you get 90dB out of it. In order to produce 93dB, you need 2Watts; to get 96dB, you need 4Watts; 99dB, you need 8watts, and so on and so forth.
(rough formula: in order for a given sensitivity speaker to up 3dB, you need to double the amplifier's output power that feeds it)
(4) home speakers are (IMHO) fairly low efficiency, with sensitivity typically around mid 80s dB/1W/1m (ref @ 2.83V) to early 90s dB/1W/1m (ref. 2.83V). Some elaborate designs that occupy horn or some kind of sound re-enforcements may get as much as mid 90s dB/1W/1m (ref @ 2.83V).
(5) tweeters, esp. those that came with ferrofluid cooling(very common nowadays)) can handle power, provided that they are being fed with AC (and no DC in it). Most of the ferrofluid cooled tweeter burnouts happen to solidstate (transistor-based) low-quality, low-power output amplifiers that clip early (or violently, depending on how you'd like to translate it) and clipping sends DC down the speaker drivers, thus killing the tweeters.
Tube amps, on the other hand, requires an output transformer (except OTL, which is another subject) and even when set to clip, doesn't burn out tweeters all that easily.
(6) how well an amplifier can drive speakers with relative ease (nowadays it is so easy/inexpensive to produce high power output with relatively less distortion than, say, 50+ yrs ago) has to do with how relatively easy the speaker impose it's loading to the amp.
If the speakers exhibit very difficult impedance loading behaviour across the entire reproducible audible audio spectrum, then even though it seems relatively high sensitivity on paper (e.g. 91dB/1w/1m ref: @ 2.83V), your may need still need a solid state amp capable of producing some serious 300Watts of clean, low distortion power in order to make them sound properly.
If the speaker impedance loading behaviour is on the "easy" side, then you don't need much (maybe a few watts to 50Watts? of clean, low distortion power) to make them sound nicely.
Sorry if this sounds overly complicated to you.
Q.
