That's a spray sealant, not a detailer.Turtle wax spray and shine, four bucks for a bottle.
Your going through the same motions so why not add the protection of a sealant? They pretty much go on the same.That's a spray sealant, not a detailer.
One is meant to be applied to a clean car for protection and the other is designed to safely encapsulate and remove light dirt while providing lubrication.Your going through the same motions so why not add the protection of a sealant? They pretty much go on the same.
Why? Nobody is going to (or should) use a detailer on a filthy car. You use it to freshen up the car that has some water spots, dust or minor stains. Spray on wipe off. You're removing the dirt when you wipe it off. You do the same with a spray sealant/wax.None of them are really "safe" to use on a properly dirty car. But a waterless wash will be the "safest", followed by a QD. Spray wax should be used when you would apply a liquid wax or any other coating, when the car has just been cleaned.
I believe you are missing the nuances here. I will let you go and do your own research if you want to learn more.Why? Nobody is going to (or should) use a detailer on a filthy car. You use it to freshen up the car that has some water spots, dust or minor stains. Spray on wipe off. You're removing the dirt when you wipe it off. You do the same with a spray sealant/wax.
Spray wax/sealant is designed for protection while providing some lubrication so your towels don't scratch the paint.What cleaning ability? The wiping IS all the cleaning ability you need, AND you're adding protection at the same time. As for research, I'm using the TW Graphine spray as such.
I feel at this point you're being purposely obtuse when it comes to certain topics.What cleaning ability? The wiping IS all the cleaning ability you need, AND you're adding protection at the same time. As for research, I'm using the TW Graphine spray as such.
Just going by my experiences using TW spray sealants to freshen up a car days or weeks after a detailing and that stays outside. Never said my opinion or suggestion was superior and nobody has to take it if they don't want to.I feel at this point you're being purposely obtuse when it comes to certain topics.
You feign ignorance so people will explain their position just so you can wave it away as nonsense and strengthen your "superior" opinion.
That's a good product. I've used it before with great results. I use ONR currently in a QD ratio.One is meant to be applied to a clean car for protection and the other is designed to safely encapsulate and remove light dirt while providing lubrication.
They're different products with different purposes. The suggestion @skyactiv made is the only other one that makes sense. And it's even safer than a QD. I prefer Meguiar's version though.
