I'm going to be putting a superstat in the Jeep in a week or 2. I've heard lots of good about them, so I'll let you guys know how it goes.
It currently has a regular Stant (looked identical to the OEM one that I pulled out), but that one went flaky after a couple months. It doesn't seem to open fully anymore, so when I'm running around backroads and basically idling along (1000 or so rpm), it starts running kinda warm (210 - 215*). The fan keeps it under 220* when stopped. If I keep the rpms up (over 1200), it cools down to where it should be (195 - 200* at highway cruise, under 210* around town).
It's a new-ish water pump, and the issue showed up after I had the cooling system drained for a radiator swap (rad capacity is fine, fan doesn't run longer than normal to cool it down), so I figure a new t-stat is worth a shot.
