Hi guys. This refers to an ad on page 55 of the May "AOPA Pilot". It pictures 3 cam followers with progressively more wear, using 3 different oils, with Exxon Elite showing the best results. The text says that the Exxon oil performs better because of it's special anti-wear/anti-scuffing additive.....dosen't mention the additive name.
The 'very' fine print says that the test results were based on a "MIRA" test rig, cam rpm 1250 (engine rpm 2500), oil temp 240*F, and spring load 195# - increased to 50% overload after 80 hours. Total test 300 hours, but was stopped early on the two inferior oils because of "severe surface damage".
Is this a severe test, or what? I'm not saying the test was rigged, but I'll bet in the real world with normal oil temps, spring pressure, and drain intervals, all three oils would perform equally well. Comments.......
