GX140 engine. This lawnmower never had any trouble starting for the past 13 years but suddenly, it will refuse to start. After much trial an error, I believe the coil stops working when it gets hot. I removed the recoil starter and the fuel tank and cleaned area around the coil and put it back and it started on the first pull!
However, anytime I turn it off and try to restart in a minute or so, it will not start at all. I have cleaned it reasonably well but with carb cleaner but I could hose down the whole area with the garden hose.
The OEM Honda coil is priced outrageously high. It comes to about $90 including shipping! Even on ebay, OEM coil is expensive. The aftermarket ones are cheap enough that i can afford to take a chance.
To replace the coil, I will need the appropriate flat feeler gauge. How tricky is to to adjust the airgap correctly? It has two bolts.
I almost want to give it up on this mower as the engine itself has no power and drinks oil voraciously. HF re-powering should be the real choice here but that might involve lot more hacking that I might be capable of. So, for the time being, it will be the cheap ebay coil.
Anybody wants me to talk out of ordering the coil?
