Originally Posted By: ARCOgraphite
Like I said, you can check 4 yourself; water will pull the alcohol out out any gas you buy and you just drain off the water (vodka for robots) on the bottom until fuel starts running. Simple chemistry 101 guys.
Here's the Chemistry 315 problem (graduate level): Calculate how much you just LOWERED the octane of the remaining gasoline by removing one of its key octane boosters. It was blended dependent on having that alcohol present to achieve its rated octane... so is it now about 80 octane (R+M)/2? Or maybe 75? 65?
I find it hilarious that you think such a fuel would be *less* harmful to an engine than E10 or E15.
For the record- Methanol works better as an additive and butynol is a better biofuel alternative to gasoline than ethanol... I'm not on the side of the farm lobby pushing for ethanol- but ethanol does WORK for that purpose and given the correct polymers used in the fuel system, its a net benefit over alcohol-free fuel.
