I need a collet for a 5/32 shaftThey have four sizes: 1/32, 1/16, 3/32, 1/8.
4485 Collets & Chucks | Dremel
Get a genuine Dremel collet set. With the 480, 481, 482, 483 collets, plus a quick-change collet nut set, you can easily use a wide range of bits.www.dremel.com
Which Dremel rotary bit do you have that's 5/32 ?I need a collet for a 5/32 shaft
It's not a Dremel bit . Hopefully I don't have to take it backWhich Dremel rotary bit do you have that's 5/32 ?
All the Dremel rotary bits that I've ever seen are all 1/8.
That's your problem lady!It's not a Dremel bit .
Even tho it fits up to 1/8 bit have you tried a 5/32 bit ?I have this on both of mine (corded and cordless), no issues in daily use. I snug it with pliers not just finger tight.
I checked the Dremel branded one and it is just a hair too small.Even tho it fits up to 1/8 bit have you tried a 5/32 bit ?
