Originally Posted By: BusyLittleShop
Sounds plausible until you under stand that an increase in flow will increase clearances
and we know that a lighter flows more than a heavier oil...
If you wish to cut unwanted noise try a set of custom ear plugs...
Quote Dr Hass
"It is time to introduce the concept of lubrication. Most believe that
pressure = lubrication. This is false. Flow = lubrication. If pressure
was the thing that somehow lubricated your engine then we would all be
using 90 weight oil. Lubrication is used to separate moving parts, to
keep them from touching. There is a one to one relationship between
flow and separation. If you double the flow you will double the
separation pressure in a bearing. The pressure at the bearing entrance
is irrelevant."
"In fact the relationship between pressure and flow is in opposition.
If you change your oil to a thicker formula the pressure will go up.
It goes up because the resistance to flow is greater and in fact the
flow must go down in order for the pressure to go up. They are
inversely related. Conversely if you choose a thinner oil then the
pressure will go down. This can only occur if the flow has increased."
But you won't double flow.
Oil pumps are positive displacement (at least the automotive ones, I assume we aren't dealing with variable displacement pumps in a Harley....) which means that for every turn of the gears, they displace a given volume of oil. Whether that's at 5psi or 50psi, it doesn't matter, the same amount of oil goes through the pump.
Now what does play a role is of course the bypass on the pump. Once a certain head pressure is reached, a certain percentage of the oil goes out the bypass and not through the engine.
However, assuming we aren't on the bypass, 5w-20 or 5w-50, it doesn't matter, the engine sees the same volume of oil. The heavier oil will provide greater film thickness and not cool perhaps as well (run a few degrees hotter) and will, due to being thicker, generate more oil pressure (back-pressure), however VOLUME will be pretty much the exact same, and may even be
HIGHER due to less leakage over the gears.
We had a neat discussion about this recently, if you want, I'll dig up the thread
Well written.
