Hello. I put Redline MT-90 in my transmission 1.5 years ago with great initial results, but the transmission has become much worse in the 50,000 km since I changed it.
I put it in in the winter and it made the synchro performance and cold shifting much better. In the summer that followed, the synchro performance got alot worse and it became hard to shift into 1st while stopped. Now, another year later, I've lost first gear and 4th is shaky, and the input shaft bearing makes an awful noise.
The car is a Toyota Tercel 4WD, which calls for 75 or 80W90 gear oil and shares it with the front diff. The mileage is low for the type of car, now only 220,000 km. My last Tercel 4WD had over 320,000, and the transmission was fine until the 2nd gear synchro went bad after 300,000.
Now I have a new transmission with under 20,000 miles on it in my garage, and I need to decide what to fill it with. I want good shifting in this trans that is known to have poor synchromesh, but not if the compromise is premature failure. I can live with changing syncrhos as they're brass and not even that expensive, and would rather do that than wear out the hardened steel gears and bearings.
