Use distilled water to flush and then fill up with coolant.I bought my 99 dodge cummins a while back and if was clear the coolant was never maintained. I took the thermostat out and it has a large amount of rust inside the housing with deep pitting. Do you get the same amount of rust running straight water as you would if it just never got changed?
Or just do what I do since we only need to change coolant occasionally you can either
do drain and refills every couple years
or
flush with 50/50 coolant/distilled water(waste the good coolant) and then refill with the same. This way you don’t have to try and figure out how much coolant to water is left in the system.
