The Critic
Thread starter
Originally Posted By: doitmyself
Water pump/weep hole? Maybe just intermittent?
I replaced the water pump recently and it is not leaking.
Originally Posted By: Vikas
Is this the same car where some chain shop had told you very bad news without doing any diagnosis?
That was someone else, not me.
Originally Posted By: tonycarguy
+1 for the fluorescent dye and overnight pressure tester.
The dye is how I found a very slow leak at my water pump. This is a DIY job. No need to take it to a chain shop like Firestone
So I got the car back today. They did a block test and it came back OK and they pressure tested it for hours with no pressure drop. The tech did find air in the system and bled it for me, so I'm not sure if that will have any effect on the leak.
