Hope this is the right forum!
I'm trying to get a deutz 2cyl F2L410 air cooled diesel running that has been sitting for awhile. It is a small air cooled engine about 20 hp. The F2L411 model seems to be a much more common engine of very similar design, when looking for parts/diagrams. I have a service manual.
Note: when cleaning up parts I noticed that the #2 cylinder side exhaust had a more black build up than the other side.
Haven't been able to get it to run yet but it is turning over fine. Fuel is getting to the injectors (injector nuts cracked to bleed air), new lines and new fuel from external tank.
Note: Exhaust and intake manifold are currently disconnected, is this OK to try to (briefly) start/run it like this?
Observations: When cranking there is some smoke coming out the exhaust, not much. What concerns me is a small puff of whitish smoke that comes out the intake on the #2 cylinder. This happens once per full engine revolution. It's just a small puff, but also if you put your hand to the exhaust, it seems like the #1 cylinder exhaust pushes out with more force than the #2 cylinder..
(Could this be normal?)
I haven't been able to borrow a diesel compression tester yet to check compression.
I am hoping / thinking it might be something valve/ lifter related, but I really don't know where to start.
Is it possible that anyone could get me headed in the right direction?
Thank you, your advice is very much appreciated
