Delvac 1 in 1983 MB 300D-turbo
JHZR2
Staff member
New Jersey
Hi,
Here is an analysis of Mobil Delvac 1 (from the local Caterpilliar dealer). Second oil change with the D1 full synthetic. 200700 miles on the car, oil changed at 3638 mi on the oil, Mann cartridge insert (this car doesnt use a spin-on filter) used. Analysis done by Wear-check USA, the analyzer flagged it for abnormal Viscosity (KV@100C=14.77), although they also had in the entry that it was for a gasoline engine, when I did certianly mark that it was diesel.
Here are the results:
Sample Date 5/14/2003
Unit Age 200700m
Time on Fluid 3638m
Time on Filter 3638m
Fluid Maint. Changed
Filter Maint. Changed
Fluid Delvac 1 full synthetic (CAT) 5w-40
Iron (Fe) 22
Chromium (Cr) 0.7
Nickel (Ni) 1.4
Titanium (Ti) 0.1
Silver (Ag) 0.0
Aluminum (Al) 2.4
Lead (Pb) 4.3
Copper (Cu) 0.6
Tin (Sn) 0.0
Silicon (Si) 5.6
Sodium (Na) 2.3
Potassium (K) 2.2
Boron (B) 111
Barium (Ba) 0.0
Molybdenum (Mo) 11
Magnesium (Mg) 427
Calcium (Ca) 2096
Phosphorus (P) 1098
Zinc (Zn) 1176
Sulfur (S) 4192
Cadmium (Cd) 0.0
Manganese (Mn) 0.3
Vanadium (V) 0.0
Soot(%) 0.9
Oxidation(PA) 75
Nitratrion(PA) 45
Sulfation(PA) 13
ZDDP 0.00
Kv@100°C 14.77
White Metal NONE
Babbitt NONE
Precipitate NONE
Silt NONE
Debris NONE
Dirt NONE
Appearance NORML
Odor NORML
H2O(Emul) NEG
H2O(Free)
Yeah, Isnt ZDDP a high pressure lubricant additive similar to Moly, that is usually present in diesel oils? If so, I have analyzed two diesel oils and also CF rated mobil 1, and none have had any ZDDP...
Maybe I can find out more info...
JMH
