Use the Power: 10 Hybrid Services You Can Perform Today
by Sam Bell
Excellent article covering all Hybrids and what you can do in terms of service and repair without specialized training or equipment .(Also , how to stay safe .)
As an example , item #7 although short AND applicable only to the prius , gives useful information on the battery ventilation/cooling system (#3) .
Excerpted ( less than 7.5% of article text ) from the MAY2007 Issue of Motor magazine .
http://www.motor.com/MAGAZINE/Articles/052007_10.html
7 Belts, wipers, HVAC system. Because the main battery pack must not be exposed to extreme heat, the a/c must work. This is not an option. The Prius has its own battery compartment ventilation < cooling > system, with a rear fender-mounted vent and an air intake on the rear filler panel. (We used to call this the “parcel shelf,” until someone realized that parcels become unguided missiles during hard stops or collisions.) It's imperative that the rear filler panel intake be unobstructed at all times .
The penalty for obstruction may range as high as $5000 for a new battery pack. Don't leave the car in the paint-baking booth, either -"
For a useful picture concerning what this is discussing go to the following thread and look at the picture of the battery area that EP has so graciously provided .
http://theoildrop.server101.com/forums/s...part=3&vc=1
EP (et al) , I believe in light of the above information the referenced thread merits a revue and doesn't deserve to be locked .
I can't be certain , but there appears to be a misunderstanding there concerning sources .
As this post makes clear , a reputable source , one of the most respected in the industry , was used , and item #7 , although not used in its entirety , was used verbatim for the quotes under question .
by Sam Bell
