Originally Posted by blupupher
I am guessing this is off the Honda?
How many miles total on it (I am guessing 196,xxx?)?
interesting looking filter, similar to a Denso made filter, but not quite.
Yes off the Honda. 196,508 when the filter came off.
This filter is essentialy a 6607 sized Honda A01 and you are correct it is quite similar to a Toyota Denso.
Originally Posted by bbhero
Am I wrong to think the 24/23/15 ISO code is not all that great at the end of the day??
It's not terrible. But it is not all too good either.. interesting that this filter and the Fram Ultra were the same ISO code...
Thank you for your work and very good pictures. Hope you are having a good weekend.
You're correct 24/23/15 is not great... it is a bit perplexing that the Ultra and this filter produced the same ISO code.
You're welcome for the pictures of course and it was actually a good weekend too.
... interesting that this filter and the Fram Ultra were the same ISO code...
Thanks for the C&P and info DuckRyder. Does HAMP/ROKI state the efficiency on these filters?
They don't. As I said above this filter is a short A01, HAMP is Honda AfterMarket Parts which are Honda service parts in other markets. I picked this filter to compare ISO codes on because it should be among the least efficient filters available.
Originally Posted by rubberchicken
I am assuming that since the oil pan is off, that something went wrong.
Read the linked thread and you won't have to assume...
