Originally Posted By: stang5
Originally Posted By: goodtimes
These are no longer made, went to China for manufacturing. I believe this filter sits base down with no filter bypass. It did a good job and the crud is where it would be expected. if this had a filter bypass it could be a lot of that dirt would have been sent to the engine bearings.
If this filter had a bypass valve and it goes to bypass mode, all this junk gets flushed back to the engine and gets recaptured by the filter?
Yes, but it goes though the engine's oiling system first before making it back to the oil filter.
If the engine has a built in filter bypass valve (like most GM V8s), then the crud in the filter wouldn't get swept through the bypass valve.
