Creme Brulee
northern Alabama
It appears that after almost 8 married years I have finally talked my wife into making creme brulee for my birthday. She doesn't like custards.
Recipe for two:
1 cup heavy cream, chilled
2 tablespoons granulated sugar plus 1 additional teaspoon
Pinch table salt
3 large egg yolks
1/2 teaspoon vanilla extract
2 - 4 teaspoons turbinado sugar or Demerara sugar
Separate the eggs and whisk the yolks after the cream has finished steeping; if left to sit, the surface of the yolks will dry and form a film. The best way to judge doneness is with a digital instant-read thermometer. The custards, especially if baked in shallow fluted dishes, will not be deep enough to provide an accurate reading with a dial-face thermometer. For the caramelized sugar crust, turbinado or Demerara sugar but regular granulated sugar will work, too. The amount of sugar needed for the topping will depend on the shape of the ramekin. Sprinkle enough sugar over the the top to cover, and then shake off the excess (about 1 - 1 1/2 teaspoons for turbinado sugar or 1 teaspoon for regular granulated sugar).
Alternate recipe:
4 cups heavy cream, chilled
2/3 cup granulated sugar
pinch table salt
1 vanilla bean, halved lengthwise
12 large egg yolks
8 - 12 teaspoons turbinado sugar or Demerara sugar
1. Adjust oven rack to lower-middle position and heat oven to 300 degrees.
2. Combine 2 cups cream, sugar, and salt in medium saucepan; with paring knife, scrape seeds from vanilla bean into pan, submerge pod in cream, and bring mixture to boil over medium heat, stirring occasionally to ensure that sugar dissolves. Take pan off heat and let steep 15 minutes to infuse flavors.
3. Meanwhile, place kitchen towel in bottom of large baking dish or roasting pan and arrange eight 4- to 5-ounce ramekins (or shallow fluted dishes) on towel. Bring kettle or large saucepan of water to boil over high heat.
4. After cream has steeped, stir in remaining 2 cups cream to cool down mixture. Whisk yolks in large bowl until broken up and combined. Whisk about 1 cup cream mixture into yolks until loosened and combined; repeat with another 1 cup cream. Add remaining cream and whisk until evenly colored and thoroughly combined. Strain through fine-mesh strainer into 2-quart measuring cup or pitcher (or clean medium bowl); discard solids in strainer. Pour or ladle mixture into ramekins, dividing it evenly among them.
5. Carefully place baking dish with ramekins on oven rack; pour boiling water into dish, taking care not to splash water into ramekins, until water reaches two-thirds height of ramekins. Bake until centers of custards are just barely set and are no longer sloshy and digital instant-read thermometer inserted in centers registers 170 to 175 degrees, 30 to 35 minutes (25 to 30 minutes for shallow fluted dishes). Begin checking temperature about 5 minutes before recommended time.
6. Transfer ramekins to wire rack; cool to room temperature, about 2 hours. Set ramekins on rimmed baking sheet, cover tightly with plastic wrap, and refrigerate until cold, at least 4 hours or up to 4 days.
7. Uncover ramekins; if condensation has collected on custards, place paper towel on surface to soak up moisture. Sprinkle each with about 1 teaspoon turbinado sugar (1 1/2 teaspoons for shallow fluted dishes); tilt and tap ramekin for even coverage. Ignite torch and caramelize sugar. Refrigerate ramekins, uncovered, to re-chill, 30 to 45 minutes (but no longer); serve.
You can also use vanilla sugar vice turbinado but we already have some turbinado sugar.
So that means we'll have to buy a torch and ramekins.
Ramekins: Apilco 5.4 oz. from Williams-Sonoma
Torch: propane or butane? I'm leaning towards a BernzOmatic propane torch at the local hardware store but which model? Surely there can be a good one had for $30 or less.
Well, the BernzOmatic butane torch is made in China. Their propane torches are made in New York.
Another recipe she considered was from Alton Brown:
1 quart heavy cream
1 vanilla bean, split and scraped
1 cup vanilla sugar, divided
6 large egg yolks
2 quarts hot water
Preheat the oven to 325 degrees F.
Place the cream, vanilla bean and its pulp into a medium saucepan set over medium-high heat and bring to a boil. Remove from the heat, cover and allow to sit for 15 minutes. Remove the vanilla bean and reserve for another use.
In a medium bowl, whisk together 1/2 cup sugar and the egg yolks until well blended and it just starts to lighten in color. Add the cream a little at a time, stirring continually. Pour the liquid into 6 (7 to 8-ounce) ramekins. Place the ramekins into a large cake pan or roasting pan. Pour enough hot water into the pan to come halfway up the sides of the ramekins. Bake just until the creme brulee is set, but still trembling in the center, approximately 40 to 45 minutes. Remove the ramekins from the roasting pan and refrigerate for at least 2 hours and up to 3 days.
Remove the creme brulee from the refrigerator for at least 30 minutes prior to browning the sugar on top. Divide the remaining 1/2 cup vanilla sugar equally among the 6 dishes and spread evenly on top. Using a torch, melt the sugar and form a crispy top. Allow the creme brulee to sit for at least 5 minutes before serving.
So is your wife getting your birthday gifts exactly as you want them? It wouldn't look good if you took them back and exchanged them.
So, we ordered the Bernzomatic torch TS700T from amazon.com. It has a trigger on/off, adjustable flame control, SS burn tube, cast aluminum body, & brass tip. It will burn propane or MAPP (but never MAPP in the kitchen). There is a pressure regulator so that it will burn in any position.
