Curious if anyone is knowledgeable in this subject.
Built a new PC for the owner of the company I work for. Although I'm normally against it (I prefer clean Windows install on new PC), he wants drive cloned from old PC to new. Can't blame him, busy guy with no time, wants PC to work just like before. I didn't see any red flags-- Intel I7-9700 platform to a Z790 Raptor Lake (13 series) w/ DDR5. Windows should place nice. Normally I like to clone the old system drive to the new one in a different working PC (that way I have the old backup in case Windows freaks out or does something dumb when you first fire it up on newer hardware), but in this case it was a SATA SSD to NVME transition (on the newer system) and I didn't want to take the time to install the new NVME drive into another system.
System fired up fine on the old SATA drive, worked just like before on the new PC. Had a few missing chipset drivers visible in Device Manager, quick work to sort that out. I installed Macrium Reflect to clone the drive, it did a couple Windows updates, I thought everything was fine. I had to erase all the partitions off the new NVME drive for cloning (I had installed Windows on it when it was the only drive installed just for testing the PC hardware), so I did so through DISKPART in the command prompt, since Disk Management will not erase system partitions off the new drive. But the old drive was left alone. Pretty simple process, or so I thought.
Restarted after new drivers were installed and was going to clone the drive. Booted immediately into recovery mode, would not go into Windows at all.
To make a long story short, I spent about an hour and a half on Google before finally stumbling across this website: (https://woshub.com/how-to-repair-uefi-bootloader-in-windows-8/) where I got a crash course in BCDEDIT and BCDBOOT executables. Had to edit a few of the entries in the BCD file by hand using BCDEDIT, but finally got the dang thing working.
Still not sure what I did wrong, I left the old SATA drive alone-- the UEFI BIOS was booting to that drive just fine, and the Windows Boot Loader entry always appeared in the BIOS for the old SATA drive. The only partitions I erased were on "disk 2" which was the new NVME drive that Windows wasn't even running off of, but that was enough to break it. I think moving the drives to another PC for cloning would have been worth the time!
