Originally Posted By: kr_bitog
Use the below link to determine the initial pressure and then adjust down 1 psi or up a few psi to find the best pressure you like.
Tire Replacement Manual
Excellent link. I saved that. Interesting, according to the table an page 8, 35-36 psi is a MINIMUM pressure for maximum load (SL tires). In other words, tire maximum load can be handled between 35 (or 36) and 44 (or 51) psi. Using that logic, the car manufacturer recommended tire pressure is a MINIMUM pressure rather than exact pressure for that particular load and tire size and type. Now, it makes more sense.
