Originally Posted By: rjundi
Originally Posted By: CapriRacer
2nd vote for alignment.
Say the alignment is off(not apparent at all in driving) then I align it. The tires are going to remain noisy?
Probably. You could rotate them and hope that in their new position they will develop a different wear pattern. They might not, but it is worth the trouble as the alternative is replacing the tires.
But before you go get an alignment, there are a couple of things you need to be sure of.
1) My experience is that the alignment tolerance (not the target value, the allowabale deviation from the target value) is too wide by half. Put another way, the vehicle has to be within the inner half of the spec.
You should find someone who will get the values there. Shop until you find one.
2) Just because the factory didn't build-in adjustablility doesn't mean they can't or shouldn't adjust the alignment. There are various ways to get adjustablility and there should be no excuse for a vehicle leaving an shop with the alignment "out of Spec" just because the operator is too lazy to figure out how to get it in spec.
3) Many alignment specs call for a lot of camber. I think anything over a degree will causes wear issues.
