LS1 Thin oil test. Test 2 of 2.
Miles on oil.....3342....2316.....2486....
Miles on unit...90,068...94343...96,829..
................M1TrSUV...HavDS....Castrol.....uavg
................5w-40.......5w-30....5w-30
Element
alum............3..........2..........3.............4
chromium.....1..........0..........0.............1
iron...........19..........3..........4............15
copper........4..........2..........2............34
lead............0..........0..........0.............7
tin..............0..........0..........0.............2
moly............6.........142.......105...........60
nickel..........1..........0..........0.............1
mang............1..........0..........0............2
silver..........0..........0..........0.............0
titanium........0..........0..........0.............0
potassium.....3..........0..........1.............1
boron.........32.........28........36.............68
silicon..........8..........4..........5.............6
sodium........3..........1..........5.............6
calcium......2503.......1628......2962.........2310
magnes.......460........44.........19..........290
phosph......1077........547.......646..........736
zinc..........1299........689.......747.........879
barium........0...........0........0..........0
Visc (56-62)...73.7,,,55.8,,,,59.1
Flash >365.....445...,,435,,,,,405
Fuel Antifreeze......0.......0.......0
Water...........0.......0.......0
Insolubles.... 0.5%... 0.2%....0.3%
Blackstone Comments: Wear continued to read well below universal averages and in the proper balance. The low and steady wear trends that your 5.7L produces are a very good indicator that your engine is operated and maintained well. The oil was in good shape physically, containing no moisture, fuel, or coolant. Insolubles, (oil oxidation due to heat, use, and blow-by) were low at 0.3%, showing good oil filtration. Silicon read normally so your air filter is getting the job done, too. At 96,829 miles we have no problems to report. This is a nice engine!
My Comments: This was the final test of two of the thinnest 5w-30 oils I could find to put in my LS1. The idea was to see if the LS1 could live a normal life without GC or a 40w oil in its belly. I think it is, in fact, very do-able. Temps have been in the 90's here in Omaha, and the car is used as a daily driver. I often sit in the parking lot at work and idle while I finish my cigar before going in and it doesn't seem to have added any fuel, but there was a long drive to Rapid City and back, so I'm sure that drove any fuel away. The daily drive is anywhere from 12 to 22 miles, depending on which way I take. I have a heavy foot so the oil hasn't been babied. I don't, however, mash the gas until oil gets to op temp.
Observations: The engine revved quickly but felt/sounded thrashy. Frantic, even. It doesn't look like it did any harm, but it wasn't what I was used to. I have GC in it right now and the motor feels back to its solid and smooth self.
Thought of the day...It worked for me, but I don't live in the extremely hot South and I didn't beat on the motor like a teenager that didn't have to buy it. Your mileage may vary. Void where prohibited. Be kind, don't litter.
Thanks for your time.
Element
