Since my last post, I have found another thread that may shed some light on this subject, or get some discussion going till we find an answer (other post by shortyb, here:
http://theoildrop.server101.com/cgi/ultimatebb.cgi?ubb=get_topic;f=3;t=000657). A theory (which sounds totally plausible to me, but I am in no way an expert) is that the concentrated fuel injector cleaner is breaking off deposits that are then making their way in to the oil. These deposits could be from unnecessarily high octane fuels, octane boost, injector cleaners, etc... These deposits can either be abrasive, or using up the base neutralizing compounds in the oil, allowing corrosion of bearing and other surfaces.
In my case, I had been running Exxon 93 octane pretty much exclusively for 2 years. My only 2 analysis showed elevated lead and iron, but below normal upper engine wear metals. The lab asked if I'd been using leaded gas, or an additive. I had used a certain Fuel Treatment/UCL several times during both oil runs. I have stopped using the FT/UCL after 2nd analysis, have run one oil change with Castrol GTX through as a "flush" (had used Mobil 1 5w30 for 2 analysis), and am getting near analysis time with my current GTX 10w30. This may help shed some light on this subject. I have also stopped using Exxon 93 within the past week, but that'll probably be a little too late to affect this coming analysis one way or the other.
BTW, my engine is a '97 Nissan VQ with less than 80,000 miles. I believe shortyb's is a 2000 Nissan VQ, with about 96,000 miles. From info I've seen, these engines normally don't have high levels of lead or iron as we both had. We both also ran 93 octane fuel (his Amoco, mine Exxon) exclusively, and treated our fuels (his BG 44k and mine Lucas).
I appreciate any comments on this subject, so please post away concerning the original post.
Dave
