I think he means the self-adhering butt connectors, which can be just as easily damaged, though I'll admit I don't have much experience with them, and the few that I used may have been junk - can't even remember the manufacturer. I'm with yonyon on this, and think option 1 is best. Nothing will last forever when it's exposed to salt (or brackish) water often, but the liquid e-tape should work well to seal up an insulated butt connector, even if crimping does open up some of the insulation.
From a novice, I've in the past used insulated butts with dielectric grease, then heat shrunk and electrical-taped the heck out of it to ensure a good seal and to protect the heat shrink.
