Originally Posted By: Tempest
Originally Posted By: ammolab
This is with the knowledge that commercial .308Win ammo may have thinner brass in the base of the cartridge cases and NATO chambers are a bit more "generous" in headspace length.
There is NO Significant pressure differences between 7.62NATO and .308Win ammo. If there is...no one has shown data to document it to date. The big 'debate' on this issue is between different pressure measurement systems that are not equal or comparable. It is "paper research" and horribly flawed. Do you see a warning on ammo boxes? Gun and ammo makers that do have pressure barrels have been VERY Silent on this debate.
I agree. I've used each in the other without issue.
Me too. I have used 7.62 and .308 win interchangeably with no bad results, same goes for .223 rem and 5.56. I find that the NATO stuff is a bit more "blasty", meaning it has a larger flash and a tiny bit more recoil but that is it. The differences are only very minor and not enough to cause a kaboom.
It is really no different than firing +P+ pistol ammunition of a given caliber. So long as you are firing it in a modern, high quality firearm that is in good working condition, you will be fine.
