I don't prefer Airbus over Boeing, you guys are conflating some of my previous posts. The Boeing stock that I bought in the summer of 2008 at $44/share has been great for my portfolio. The 747 is my favorite airliner and I've posted many times on my appreciation for that incredible jet, including pictures of my bookshelf, with 747 Model and books on the airplane. I chose to be a 757/767 Captain over A320 Captain because, wait for it, I like the airplane better, even though my seniority would be better on the 'Bus...and I love the 757/767 as an airplane in addition to the places that I get to fly it.
I have no love for the 737, however.
The 737 was designed in 1964. First flew in 1967. First flew with UAL in 1968. The airplane has been modified, but it is a 50 year old design. The fuselage has been stretched, but you cannot remove the fundamental shortcomings of the airplane: short landing gear, cramped cockpit, narrow fuselage. You would call a 50 year old car an antique, and this airplane deserves the same appellation because the same frame (and limitations) underlies every
single model.
The airplane was conceived as a short-haul feeder for international flights. As a short-haul airplane, it's fine. But the short landing gear (to keep costs down) limits the airplane. It's the only modern airplane that doesn't even enclose the wheels inside - they're part of the skin and a missing hubcap renders the airplane unsafe for flight because it's part of the exterior. That short gear limits the body angle of the airplane on takeoff and landing, which limits the lift that can be generated without hitting the tail of the airplane. The more you stretch the fuselage, the worse this limitation becomes.
Good in a crosswind?
Yeah, the gear casters about 4 degrees. So, a pilot doesn't have to be as good to get a good landing in a 737...but the crosswind limits are the same as the A-320, and a bit lower than a 747/757/767, and the split scimitar winglets lower the crosswind limits slightly (ground clearance). So, good? yeah, but not better than any other airliner. And worse than many. It's better than some RJs, but that's like saying that your car out-performs some mopeds...
The cockpit
Miserable. Noisy. Cramped. With a trim wheel that has, and will continue to, whack pilots in the knee. A 50 year old anachronism, like the overhead panel that looks like a 707 engineers panel. Dated, confusing, and likely responsible for the death of everyone aboard Helios 552. If all you've ever flown is a 737, you probably love it. If all you've ever driven is a 1963 Corvair, with its swing axle suspension (also a 50 year old design), you probably think that's great, too...until you drive something newer. 777 flat panel displays? Sure, it's got those now, sandwiched in between the 1964 overhead panel, the trim wheel and the same ergonomics that were cheap and lousy 50 years ago.
Safe?
This is
one of the largest travesties ever from a government agency: the FAA response to the discovery of a fatal design flaw in the 737 Rudder. The original 737 rudder design included an actuator that would go full deflection without warning or input. Imagine that you bought a car in which the steering would suddenly snap full left or right, with no warning. Safe? Yeah...sure... So, after two fatal crashes, in which the rudder of a 737 went hard over, rolled the airplane over instantly, and killed everyone on board, the FAA gave airlines 18 months to install new rudder PCU (hydraulic actuators). So, we have an airplane, the 737, with a design flaw that resulted in two confirmed fatal crashes, but they're OK to keep flying? How could this be?
Well...let me be blunt. It would have put a couple of airlines out of business, so, the FAA gave them 18 months. And 737s flew, from 1997-1999, with a rudder actuator that had killed, and might kill again. The airplane was simply uncontrollable if the rudder went hard over at certain flap/speed combinations. But you wouldn't want passenger safety to be put ahead of the economic interests of those airlines, would you?
Airbus design philosophy has come up in this thread, and I've discussed Air France 447 in detail. But this isn't design philosophy, this is design flaw, and it had two confirmed fatal crashes and still remains suspect in several other crashes. The roof ripping off the airplanes (737s) isn't a design flaw, by the way, it's happened, but that's a matter of fatigue, of bean counters pushing short-haul cheap airplanes to the limit of service life.
Performance limited?
Oh, yeah. I can't tell you how many times I've been stuck behind/below a Guppy. It's like having a highway full of 1964 Beetles that climb hills, in the left lane, no passing, at 40 MPH. They cruise at 60 on the flat, in the left lane, and no, you can't pass them. They cruise more slowly than other airplanes, and they climb more slowly. Newer versions are better, but for 5 decades, they've been the speed bumps of the air.
Originally Posted By: andrewg
Is it a "dog"? Well, I suppose if you are flying out of the Peruvian Andes, heavily loaded, it might seem so. And we all do that frequently.
Or, if you're flying out of a SEA-LEVEL airport with 12,000' of runway.... You see, that stubby landing gear, that limits the pitch, is the reason that the 737 NGs that UAL was flying out of LAX (field elevation, 128') had to take off for Hawaii with 40 empty seats. Yep, the beancounters who buy airplanes bought the airplane sales pitch, only to find out that their brand-new airplane couldn't fly max range with full fuel and passengers from a sea level airport with long runways.
Gentlemen, if you can't get airborne with full fuel and a full passenger load from a sea level airport with 12,000 feet of runway, you've got yourself a DOG of an airplane. UAL has quietly replaced those dogs with a real airplane: the 757 on performance-critical routes from SFO and LAX to Hawaii. DEN-HNL is, of course, a 757 only flight...because when you need performance, the 737 will let you down every time.
Best-selling airliner?
Yep. No doubt. Good for Boeing, good for my portfolio. But beancounters buy airplanes, as I mentioned earlier. McDonald's has the world's best-selling hamburger. Not the best hamburger. Maybe not even good. But best selling, just like the 737.
For exactly the same reason...
https://en.wikipedia.org/wiki/Boeing_737
https://en.wikipedia.org/wiki/Boeing_737_rudder_issues
