AGM batteries vary more widely in acceptable absorption voltage and float voltage then their flooded counterparts.
I spoke with an Odyssey engineer and he said if I could not float their battery at 13.6v, not to float it at all, that it would sulfate at 13.2v.
Regarding voltage at the end of charge, My Northstar AGM accepts more amperage at lesser voltages than the previous flooded battery, by a good margin.
I use an adjustable voltage power supply to manually recharge from the grid, and when I cannot be there, when amps will taper to 0.05% of capacity at 14.46v at 77f, to lower voltage manually at that point, I lower voltage to 13.6v, the recommended float setting and can leave it unobserved with no fear of overcharging.
To my initial surprise with this AGM, while the battery is accepting say 7.8 amps at 14.46v and tapering slowly in this constant voltage absorption phase of charging, lowering voltage to 13.6 the amps it accepted were still above 6.
A flooded battery in this same state of charge, and voltage prematurely lowered prematurely to 13.6, as most every automatic charger will do( the premature revert to float), the amps taper to 1.5 to 2, 1/3rd of that which the agm would require at the same state of charge to be held at 13.6v
And thus time to full takes about 12 more hours at 13.6v, where it would have taken only about 2 more hours at 14.4.
I use the AGM setting on my Schumacher sc2500a to charge a flooded battery. I do this as it keeps the whack job Schumacher from exceeding 15 volts, and it will actually hold absorption voltage for longer. It might flash the green light, but it will stay at 14.4v for longer than it will on the flooded battery setting, bettering the chances of a full charge, and it floats at 13.6v.
I'd not let it float a flooded battery for a week at 13.6v but for a few hours or overnight, it will bring the battery that much closer to a true full charge.
Put an Ammeter in line on a charging source can really open ones eyes as to what is going on.
This one will count Amp hours, and display voltage, wattage, watt hours, minimum voltage, Amp peak, watt peak.
Do NOT trust the voltage display on the charger no matter how much you want to, until you verify with a digital multimeter directly on battery terminals. It might be accurate at a 2 amp charge rate and be 1 volt off at 20. My Schumacher is 1.2 volts off at 25 amps, reading low.
Do not use with a charger capable of more than 25 amps:
http://www.amazon.com/Makerfire%C2%AE-Precision-Power-Meter-Analyzer/dp/B00ORGDQOK/ref=sr_1_sc_1?ie=UTF8&qid=1459368875&sr=8-1-spell&keywords=gtpower+wattmeter
This can give you an idea of the health and state of charge of the battery when one uses the charger, and give clues to the chargers operation too. If a 100AH battery required 50AH before the charger reverts to float voltage, well figure a 10% loss for charging inefficeincy, and the battery was around 60% charged when the charger was plugged in.
But if the minimum voltage recorded was 10.6v, and this 100Ah battery took 50AH before charger shut down, and/or reverted to float voltage, then this 100AH battery might have only half of its remaining capacity available, as 10.5v is considered 100% discharged.
One can also use this wattmeter to gauge the performance of the charger. When the charging source reverts to float voltage, Unplug charger and wattmeter and apply a load to battery just long enough to drop voltage to restart charger on next lowest amperage setting. Se how many AH the wattmeter counts before the charger reverts to float voltage again. Often you will find that one can squeeze in 5 to 10% more AH compared to the first time the charger stopped and reverted to float voltage. Proving the battery was not full when the smart charger declared it to be, the first time.
Also one can see how much more the battery accepts at float voltage, if one just restarts the charger without bleeding off the surface charge and voltage is still above 13 when charger is restarted.
The wattmeter inline will prove the soothing green light indicating a full charge, is a pathological liar, most of the time, but especially on a deeply discharged battery not in the greatest of health to begin with, when it was overdischarged.
If one is really interested in the battery state of charge, then measuring how much amperage floaw at voltage and how much Wh or AH was sent to the battery is very enlightening.
Trusting the green light on asmart charger is akin to driving without an odometer, speedometer or fuel gauge, and hoping for the best. You might not run out of gas, but when you do it could be a total surprise.
