Hello everyone. I'm going to be posting some test results for Larry. I'm retired now and I'm going to drop of the map in a couple of weeks to my cabin in Idaho. On to the test.
4 Honda Civic's were picked. One was given a maintenance dose of 4 oz's, one was give a 3 oz dose and two were given a 4 ounce dose of 5w-30 engine oil. None of the drivers knew what they were given but all were told that it was an additive the would improve their gas miles. We tracked their mileage for three tanks before the test began. I will post the numbers below but a summary of the data goes something like this. All 4 vehicles experience better mileage on the first tank of fuel. The two with the engine oil placebo quickly returned to lower mileage number in fact numbers below the three tank before test numbers. The vehicle with the 4 oz dose dropped on the second and third tanks but started to improve from tank 4 up to tank 6 and leveled off. The vehicle with the 3 ounce dose was withdrawn when Larry discovered that it had major sludge problems and it was put on a 20 ounce clean and then a rinse. In its cleaned condition the mileage and compression was up dramatically. All tanks were run to as close to 300 miles as possible to keep the testing easier and still consistent. It appears that the 4 oz does improves mileage and compression. The three oz car was discovered to be a sludger when if failed a smog test required for registration and passed after the clean and rinse.
All drivers were asked to drive carefully but no coasting or turning off the engine a lights or other hyper mileage tricks.
3 tanks before test////Start 1st tank on
#1 placebo 33.5/33.0/34.2 //35.1/34.0/33.6/33.1/32.8/33.3/34.0
#2 placebo 30.2/31.0/29.9 //31.9/31.5/30.0/30.0/29.8/30.1/30.5
#3 4 oz dose 34.2/31.2/33.9 //35.5/32.2/33.0/35.5/37.2/37.5/37.1
//37.5/36.7/37.0/
#4 3 oz dose 29.3/29.0/30.1 //30.7/26.5/27.9 -stopped
Comments on #3. After the placebo effect wore off it looks like it took Auto-Rx some time to start working but it appears that there was a useful increase in mileage over the length of the test. We tracked the mileage on #4 for a few more tanks. If we say that the starting mileage was about 34 and the ending mileage is about 37 and when he goes back to his normal driving habits I think we can say that he has a 5 to 7 percent increase in mileage and a useful increase in compression. As a subjective comment the car feels smoother and starts easier.
One final bit of trivia about #3. We hooked up a Watt meter on the starter before testing and got 1825 Watts. After the test the same procedure gave us 1770 Watts. I think this means that the engine was easier to turn over after a while on the 4 ounce maintenance dose. These numbers are the average of three runs on the starter. I know it's not science but at least it's interesting.
Compression before/after 4-5 tanks with Auto-Rx in the oil.
#1 185-180-188-165 after 185-175-180-170
#2 188-180-170-175 185-180-175-175
#3 185-170-175-180 188-185-188-185
#4 165-170-168-165 -> after clean & rinse 185-180-185-182
Lab work will follow along with smog test numbers.
Barker
//37.5/36.7/37.0/
Barker
