Was looking thru the latest issue of a Construction Equipment magazine and Shell has a "info" article on Rotella T.
The test was running (2) Cummins 600 engines pulling road trains for 186,000 miles in the outback with temps over 100F. Cooling towers are used for differential oil. Tractor/trailer length reached 174 feet, and weighed as much as 396,000 lbs. Test engines averaged 2 miles per gallon compared to 6 to 7 mpg for a typical rig here in the states. The fuel burned would be the same as a typical rig here running 600,000 miles.
Article stated at teardown valve deck, gear cover and oil pan had minimal sludge buildup. Cylinder liner crosshatch was preserved. Minimal deposits on piston crown, ring grooves and ring belt practically free of carbon deposits.
Engines maintained per factory recommendations and oil analysis never showed elevated contaminate levels. (uoa's not included)
