Originally Posted By: unDummy
Unless they can give you a TSB that shows that the PN was superceded
No they just stated that the other p/n I was asking is still available, but that is not what they're using. I guess I'll stay away from there for everything transmission related in the future!
Originally Posted By: ewetho
I am Suzuki Gold Tech and a Forenza uses Esso LT71141 NOT T-IV (Mobil 3309). Suzuki traning specifically forbids the use of Dex/T-IV.
From what I can find it is a ZF made trans...
That's what I feared... at least I double checked here before using the fluid. I guess I should forget about getting a refund on this, since they're so convinced I got the right thing.
I might settle for the Valvoline Maxlife ATF option, they confirmed to me via email that one of their product should be fine for me.
Quote:
Oh yeah, the drain and fill plugs are 5/16" (8mm) Pipe Plug. Then works great.
Are we talking about round expanding rubber plugs? Thanks for the tip, I was banging my head trying to find a solution for this. Closest guess was to grind a 1/2" socket adapter into a square 8mm.
