A friend of ours has a 95 dodge shadow 3.0L V-6 FWD automatic with 100,000 mi which has been losing transmission fluid & reverse doesnt engage for at least 1 second then feels like a neutral drop. Forward gears engage normally. Had minor seeping around the output of the transmission but stayed dry when I cleaned it up with brake cleaner. Fluid level & color is good, owner said she has been using atf+3. I added about 1/2 bottle of arx hoping that it will help with the reverse & seeping. Has anyone had this problem? Did a search but most transmission problems were forward gears not working right.
