I'm sure there's a quick answer for you ..but since I don't use that thread filter - I can't seem to remember the longer numbers for anything except the 3/4-16 threads.
Here's your PL24651 in WIX
Part Number: 51372
UPC Number: 765809513723
Principal Application: Ford/Lincoln/Mercury (91-07), Mazda (00-07), Cadillac STS-V, XLR-V (06-07)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.167 (Donaldson is 5.5")
Outer Diameter Top: 3.660
Outer Diameter Bottom: Closed
Thread Size: 22X1.5 MM
By-Pass Valve Setting-PSI: 12-15
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=12/25
Burst Pressure-PSI: 275
Max Flow Rate: 11-13 GPM
Nominal Micron Rating: 19
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.834 2.462 0.200
Putting the thread into Donaldson ..and then putting those numbers back into Wix again, you get...
Part Number: 51087
UPC Number: 765809510876
Principal Application: Ford European-Dorset Engs.
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.477
Outer Diameter Top: 3.661
19
Burst Pressure-PSI: 355
Nominal Micron Rating: 24
Gasket Diameters
Part Number: 51592
UPC Number: 765809515925
Principal Application: Cummins, Komatsu, Onan Engines
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.214
Outer Diameter Top: 3.663
By-Pass Valve Setting-PSI: 18-20
Burst Pressure-PSI: 250
Nominal Micron Rating: 16
Gasket Diameters
15614 2.834 2.462 0.255
Again, I'm sure that there's some "canned" answer for you ..
