This is a friends and they live out in the country about 15 miles. The air filter was nasty and looks like the original one, oil filter was a Pure One. I don't know how long the OLM was at 0% but it had 10,168 miles on this oil change
Which was AMSOIL OE 5w-30.
Code:
Here is what Blackstone commented: Universal averages for a GM 3.6L V-6 show typical wear after about 6,100 miles on the oil. You went longer on
this oil, which is partly why iron read so high. We'd expect it to read closer to 40 ppm after ~10K miles, so the extra iron
shows some wear at steel parts. Sodium was high, but it looks more like an additive from a previous oil rather than
coolant. Silicon could be abrasive dirt or harmless sealer, but check the air filter to be safe. We found some fuel, but
not a problematic amount. The TBN was low at 0.8 (1.0 is low) and the TAN was okay at 5.7. Try 8K miles next.
OIL OEF 5w-30
MILES IN USE 10,168
MILES 69,787
SAMPLE TAKEN 10/17/13
ALUMINUM 6
CHROMIUM 1
IRON 75
COPPER 4
LEAD 0
TIN 0
MOLYBDENUM 69
NICKEL 0
MANGANESE 1
SILVER 0
TITANIUM 1
POTASSIUM 2
BORON 32
SILICON 41
SODIUM 45
CALCIUM 2189
MAGNESIUM 12
PHOSPHORUS 765
ZINC 892
BARIUM 0
INSOLUBLES 0.2
WATER 0
FLASHPOINT ºF 335
SUS VIS 210ºF 55.9
cSt @ 212ºF 9.03
Fuel% 1.5
Antifreeze% ?
Water% 0
TBN 0.8
TAN 5.7
Code:
OIL OEF 5w-30
MILES IN USE 10,168
MILES 69,787
ALUMINUM 6
CHROMIUM 1
IRON 75
COPPER 4
LEAD 0
TIN 0
MOLYBDENUM 69
NICKEL 0
MANGANESE 1
SILVER 0
TITANIUM 1
POTASSIUM 2
BORON 32
SILICON 41
SODIUM 45
CALCIUM 2189
MAGNESIUM 12
PHOSPHORUS 765
ZINC 892
BARIUM 0
INSOLUBLES 0.2
WATER 0
FLASHPOINT ºF 335
SUS VIS 210ºF 55.9
cSt @ 212ºF 9.03
Fuel% 1.5
Antifreeze% ?
Water% 0
TBN 0.8
TAN 5.7
