S speedy341 Joined Sep 16, 2003 Messages 172 Location Laurel, MD Jan 19, 2004 #1 Is aluminum complex waterproof grease ok for u joints? Also, how often do you lube them?
MolaKule Staff member Joined Jun 5, 2002 Messages 24,039 Location Iowegia - USA Jan 20, 2004 #2 Yes, if the grease has moly and other EP agents. I would not use anything less than a moly fortified (#2) grease. I regrease every 30,000 miles if hauling. Every 75,000 miles if not. Depends on your vehicle weight and use.
N Neil Womack Joined Jun 9, 2002 Messages 718 Location Central Texas Jan 20, 2004 #3 Speedy I use Schaeffer's Aluminum Complex grease on the Power Take-off u-joints for several pieces of farm equipment. This stuff is great. I no longer have to grease at 8 hour intervals as I did with Lithium Complex. These u-joints differ from your automative u-joints in that they are exposed to the lots of dirt and water plus take lots of shock loading. So it should work even better in an automotive application.
